Is it possible ?
monkeymoreton
I'm going to have a go at saving it but I think someone has "saved " it before as the piston is aftermarket
Sent from my LG-H850 using Tapatalk
As Spud said the bore may be ok if the nikasil layer is intact (it's only 0.4mm thick).
Whilst Meteor pistons are available for about 20 quid beware that the cylinders may be chrome plated rather than nikasil.
A reason why an after market piston will fail is that the aluminium pick up adhering to the bore has not been thoroughly removed. It really needs to be done by dissolving the aluminium from the nikasil
