Hi all the information I find on this topic is very unclear I am
Level 3 qualified in Arb in the U.K but can't seem to make sense of what level this is in New Zealand is it's still level 3 by there standards?
Thanks for any help on this.
Dave
Hi Dave
If you search on Google enough you will probably find a comparison table but you will probably need to go through the European Qualifications Framework (EQF) rather than our RQF.
I've had a quick look and they seem to have 10 levels whereas we have 8 plus 3 entry level at the bottom making 11. This splitting of the entry levels is a relatively new thing though from what I remember. Brought in when the old QCF changed to the RQF. The higher quals look relatively straight forward.
L8 - PHDs are L8 in UK and L10 in NZ.
L7 - Our L7 appear to be split in 2 over there - L9 for MSc and L8 for Post grad dips and cert.
L6 - BSc is L7 in NZ.
L4 and L5 - Higher education dips and certs in UK - these appear to be L5 and L6 over there.
This leaves 4 levels at FE. This is probably equivalent to our L1, L2, and L3, plus the entry levels. So yours I would think would be either L3 or possibly L4 over there. This is just my opinion as I have only looked quickly.
What is your L3?
Cheers
