Light bar wiring
simonm
Hi
Firstly you need to understand that power in Watts = Amps x Volts - so if you have 120Watts of light they will draw 10 Amps from a 12 volt (nominal) battery
ie: 120W = 10A x 12V.
So you need to first calculate the current your lights will draw, if it is significant then you need to allow sufficient cable capacity, fusing & a relay to handle it.
In my above example of 10 Amps draw for a 120 W light, I would double the current carrying capacity of the cable to 20 Amps - or more perhaps 30Amp & use a 15 Amp fuse to protect the cable run.
The fuse must be rated accordingly to permit it to blow before the cable melts & causes a fire.
I would use a relay to switch the current again rated at the same of the cable 20Amp maybe 30Amp, The relay switching circuit carries minimal current, perhaps a few milliamps, so that is not significant & you could spur it from a separate fused circuit.
The main supply, i would take from the battery, via a suitably rated fuse, switched through the relay.
Thats how I would implement it
N
