Hi,
We have a Jensen A530t 2007 model. Can anyone help with service advice.
1. How do you drain hydraulic oil to replace with fresh. I have accessed filter etc by removal of the side panel. Is there a specific drain plug for the system ?.
2. Flywheel drive belts are loose. I understand you can adjust by undoing engine mounts and resetting . I've taken a good look but can't work out how to proceed. Anyone got any photos or guidance.
3. There is an inline fuel filter in the engine bay. Does this model have a secondary screw on filter.
Any help very much appreciated.
Cheers.
The fuel filter will be found along the fuel line. Follow it from the fuel tank.
The oil filter is easily spotted on the side of the engine, low down. Stan old oil through the sump plug.
If it's like my last A540, tension the belts by adjusting the engine mounts.
Why on earth do you want to change the hydraulic oil?
