stihl fs 490
andy fellows117
Hi to all, just a quick question, I have a fs 490 clearing saw without heated handlebars as I live in Finland it is starting to get cold, is it possible to fit heated handlebars on the saw if so what would I need thanks in advance.
I have no experience on this model, more on chainsaws with heated handles BUT, the power comes from a magnet embedded around the flywheel (flywheel needed), this passes around a circular coil behind the flywheel (coil needed). There will be a wiring harness for the handles, a left and right handle or at least a heating element for both and a switch to turn them on and off.
The parts would be relatively tricky to fit.
