Just wondering what people's pros and cons are of the various systems offered.
I have heard that there are some limitations or/and that people use different systems for different projects.
Hopefully this will give me, and possibly anyone else looking into this, a more complete picture of these systems' capabilities and limitations.
Please give your input and then I will try to compile it all together into a concise format.
I have only tried Pear Technology, Kobo collect, QGIS, QCAD.
So here is my start to it.
Data Capture
Pocket Gis
Price: £500+
Pros:
Works with Android and Windows
Only need one device to carry map and data capture
Works with GPS or without
Allows plotting directly on an imported map
Can edit data input fields in the field (though more tedious than in the office, unless you have a full Windows device perhaps)
Can use existing templates for input fields which you can then modify to your needs
Cons:
Does not work with Mac
Android version takes a bit of getting used to (only one I have tried)
Kobo collect
Price:free
Pros:
Can make your own input fields
Can work with GPS
Very clean and simple interface
Cons:
Cannot edit input fields in the field
Does not allow plotting onto a map in the field
Exported csv files are not "clean", for lack of a better word
Limited number of characters in response field
Mapping Software
PT Mapper Pro
Price: ~£850
Pros:
Works directly with Pocket Gis
Can import csv files
Relatively user friendly
Good support
Cons:
Not Mac compatible
Doesn't allow group RPAs, canopy spreads and shading without overlapping each tree/shrub in the group (not easily anyway)
Does not import or export dwg files.
Some incompatibilities between dxf files imported and exported.
Any editing done to most tree attributes must be done in the csv file prior to import.
I will have to add QGIS and QCAD later as I don't have anymore time right now.
