White rot in oak
Undercut
I have milled up some oak planks, there is rot in the tree mostly in the outer layer, it's the white rot that makes the wood soft, an inch or so in the wood is solid, looks like a mycelium of sorts, just wondering would this continue in the milled timber, or as the tree is felled would the rot only be contained to the areas already affected.
Cheers
