You will always get a more inconsistant chip size with a disc chipper than with a drum machine, IMO if you are needing a G30 chip for a boiler a disc chipper is not the way to go the big lumps will cause chip feeding problems. Even drum machines get larger straifs especially from the cut end of the timber. As already stated speeding up the fly-wheel and slowing down the in-feed will help. I hope you get the chip quality that you need.:confused13:
