Every year field grown nursery trees are harvested leaving ruts up to tractor belly depth in places. All we've used is a set of disc harrows and a bomford heavy duty type chisel plough/drag.
I heave the wet spots from either side with drag if bad around April time. Also do the rest once. Then once it's dry run through again including wet spots.and Harrow off to level and consolidate.
Your wet spots will only be Surface compaction. Underneath soil will be nearly as dry as rest of land. In Most cases.
Just to clarify their is people who can. Sit in a digger looking fluid and competent, then there are digger operators, who think and do.
Using a well intentioned matey one weekend cheap might cost more long term.
Keep us updated👍
