Hi David
It could be that the no stress unit has developed an internal fault, to test the machine please perform the following test,
With the machine in a safe condition and turned off, find the 2 by pass wires for the no stress unit, these are located underneath the box and are 2 wires twisted together with bullet point connectors, connect the wires together and try your machine, if it works OK then it points to the no stress being faulty, If it is still the same then there are a couple of other tests that can be performed, and it would be easier to talk you through them rather than trying to explain in text.
Call me if you require further assistance my number is 01449 765820
regards
Timberwolf Tech Support
