Hi
I have a 2001 TW125 single feed roller, the stress control has the green light showing on it, the roller rotates even on idle, all the buttons are working but the stress seems to not work, think this may be the reason the previous owner blew the engine up. Any ideas what causing this? Would rather not blow up the new engine lol :001_unsure:
Thanks
Dom
Hello
If the forward feed rollers turn at any rpm it would suggest either a fault with the no stress box or the wiring through the forward latch circuit is shorting to ground.
On older machines such as yours it may be one of the directional valve coils has corroded and no longer insulated from ground at that point.
I suggest the machine wiring is checked out by an authorised Timberwolf dealer or Auto electrician as soon as possible.
Hope this helps :thumbup1:
