The cat section looks as if it should lift right out of the front cover ( in the IPL the exhaust is shown in three sections) but I found it impossible (without going mad) to separate the cat section from the front, (it may be a very tight push fit) so I just put the exhaust in a workmate and used a drill to remove the cat material itself .
Thanks for that...i came to the same conclusion on initial inspection and looking at IPL . Im getting a new muffler and will mod the old one so il pull the old one apart and find out its construction.
