Uniforest 50eco vs kellfri 5t winch
Bennovet
Looking to buy a winch for on back of JD 2650,
Both these winches seem good value for money.
Uniforest 50ECO
Description
This Winch is suitable for medium size tractors but has all the functions and characteristics of the large winches. The lower pulley is not included but can be ordered as an option. This winch is suitable for customers looking for a professional build but lower specification which is reflected in the price.
Specifications
Pulling force 50kN
Wire rope medium speed 0,90 m/s
Wire rope length / diameter Max.(theoretical):
100/10 m/mm
90/11 m/mm
75/12 m/mm
Standard:
70/11 m/mm
1960N/mm2
Recommended tractor power 33 - 50 kW
45 - 70 km
PTO Shaft revolutions 540 min-1
Dimensions
Width 1500 mm
Depth 480 mm
Height without safety guard 1430 mm
Height with safety guard 2300 mm
Weight without wire rope 366 kg
£ 1,800
Kellfri
Log skidder winch 5 tonnes with a speed of 0.5-1.3 m/s. PTO shaft included.
£1,590
Kellfri's Log Skidder Winch with 5 tonnes capacity is designed for demanding use and is the perfect tool for more demanding winching work. The log skidder winch makes it possible to successfully conduct forestry work, even in difficult terrain. The winch has a drum brake, adjustable lower wire tackle, and mechanical locking of gears. Height of lower/upper return wheel, 700/1,450 mm. Recommended minimum tractor size is 40 hp. PTO shaft, dead man's switch and lower guide pulley are standard.
Many thanks
(Just received confirmation on Small Grant funding so boy in a toy shop! Will make another post re: grab
