Shindaiwa 352s
mike68
Shindaiwa 352s
I got hold of the above for $20 aus (about 10 sterling)
the chap said it was lacking compression and he thought the piston may have been knackered.
I took it to bits and cleaned it, the carb was gunky inside so cleaned with carb cleaner.
I took the cylinder off to look at the piston which was smooth and clean, as was the inside of the cylinder.
once I'd put it all back together (with no spare bits!) it did start.
The chain would not run freely , it was really stiff and I have seen more meat on a skeleton! Also the sprocket at the end of the bar wouldn't move freely , it was really stiff. So I removed them. I have a spare B&C which I fitted.
When cleaning the carb I took the L & H needles out and reset them from info gained here
http://www.golftechs.us/Manuals/shin...aw_current.pdf
http://www.garage24.se/Catalogs/Shin...rjustering.pdf
As I said it starts and runs but it is quite smokey especially when revving.
Please could someone advise on what to do to "tune" it
I only have a screwdriver and ears!
Thanks
Mike
There's probably a lot of oil in the crank. Get it running and run it till it is properly warmed up on fresh fuel with the correct oil ratio. Is it low on compression or is it the easy start confusing the issue ? Look on Youtube for tuning a saw videos they are a good source of information and pretty much the same for all makes.
