Dragging memory but isn't the disc held to the hub by the wheel studs? Remove hub, put it on its back supported by a couple of wooden blocks and drift the studs out and voila. Lay new disc down on wood back side up, line up with hub and drift studs back through.
Get confirmation though in case I'm confusing with another Nissan.
Yep did that took five studs out can't see anything else holding it, tyres forcing it off and broke it but still not come off? I'm scared of breaking the hub to if I apply any more force
