yeah, i think using a router would be best/easiest. Used to work as a cabinet maker in a previous life. Router would probly be most accurate too and less faffing about. would only take about 5mins!!
EDIT:
sorry just re-read the origonal post!!
considering the width of the sign, a dimention saw with adjustable blade would probly be best!!
id recommend going to a furniture workshop if there is any near you!!
Edited by Ooops..
payed more attention this time!!
I would clamp the Hazel rod between two straight lengths of timber.
In fact you could screw cross small pieces to the timber to clamp them together & hold down the Hazel rod at the same time.
Then simply run it though a table saw with the blade lowered to the appropriate depth.
Make several passes with the saw & adjust the guide if you need it wider.
