Kawasaki TD40.Vintage.
mikerecike
Running erratically and over revving symptomatic of air leek. Carb cleaned and new manifold gasket made. Resealed cylinder with Dirko. Still lame and over revving.Pressure and vac test show<d leak in recoil side crank seal. Couple of questions -I can see bearings now seal removed should I white lithium grease them before replacing seal? Second Q. Number I can see on seal is AD0587E -25MM Outside diabetes. Can't seem to find that number online -any suggestions re:supplier?
