The outer blade on my entec 6" is wearing unevenly on the outer edge. This has only started to happen after I changed the anvils. The blades don't appear to be catching when turned over by hand.
Thanks
Hello scale90
This is a difficult one to determine the cause without seeing the machine. As this has only started happening since you changed the anvils I would suggest the machine is taken to an authorised Timberwolf dealer for inspection, if the blades and anvil make contact this could result in an expensive repair.
Details of your nearest Timberwolf dealer can be found on our website Timberwolf | wood chippers | shredders
Hope this helps
