What's the most boring vid you've seen?
First off, I tried putting this in 'Off Topic' but I wasn't allowed.
But back to the vid and after you've watched it. Or pulled out your finger & toe nails with pliers, as this might be more enjoyable. You'll understand why I chose this forum.
[ame]
[/ame]
I reckon there ought to be a law - if you're in the shop looking at video cameras, the assistant has to ascertain:
A. Will you think it through first and do you know how boring it is, to have the same detail pointed out in every instance?
B. Or just ramble on and on and on, with no preconceived idea of what you'll say next?. And will your audience see you forefinger pointing on-camera?
C. Do you know what 'edit' means?
D. Were you/are you the one people try to avoid in crowded areas. For fear that they'll lose the will to live if you stop to chat?
If the answer is 'No' to A and or C
If the answer is 'Yes' to B and or D
Then you should be barred from owning such a dangerous weapon of mass boredom.
So, what's the most boring vid you've seen lately?
