Hi Guys,
anyone having same problem with me?my brand new bg86c-e has oil leakage from muffler(where top 2 holes are) took it back to the dealer,they told me its normal for new models of bg86 c-e's to get rid off the oil that way so its so envirementaly friendly???:001_huh:
customer wouldn't like it if it drips on their expencive patio etc.:blushing:
I would like to hear your valuable opinions about this blower issue.
:thumbup:
Hi Guys,
:thumbup:
If you are getting oil coming out of the exhaust, it sounds like there is too much in the fuel/oil mix. Two strokes should burn off any oil in the mix used and next to nothing should remain as a fluid to drip out of the exhaust.
A blower would be used flat out so even less chance of it building up fuel/oil mix. Is the carb adjusted correctly - too rich and it may do this but also wouldn't rev out well and would smoke!
thanks mate.
I will buy Husqvarna blower next time.i might get lucky!
Just checked the IPL, there are three types of exhaust, one has a spark arrestor that unscrews from the exhaust outlet so if your blower has a hexagonal nut around the exhaust outlet - undo it and take the screen out as it may well be blocked and be blowing out around the muffler bolts!
