We have a grab and rotor on our old grey cab 3cx. The grab came with a solenoid already mounted on it. We just connect it into the bucket curl ram pipe using agricultural quick fit connectors which aren't ideal. It will eventually have a proper tee piece and valve. The power is provided by an old guitar effects pedal in the cab with the wire carefully routed through hose pipe along the back actor. It works really well although it took several attempts to make the wires work with the extender hoe and still be removable.
Edited by landroverfanatic
