It's not , the stub axles are welded straight onto the bottom of the oil tank one pot hole and that would be upside down
I must admit I wouldn't be happy towing it on the road.
It does have Indespension units on it, rated to 45mph. If I were to tow that on the road, it would only be for short journeys I think.
I use that exact splitter at work and for the money it's a great bit of kit. So far I've not found a bit of wood knotty or otherwise that it can't get through, it is propperly road towable with indispention units however the tyres are only rated for 45mph and you need to add a light board to stay on the right side of plod, overall it's not the fastest splitter you can buy but it's much cheaper than the better known faster brands. so far it seems well designed and built and I'd happily recommend one
Cheers Graham
  • 3 months later...
