They are heavy, slow-revving lumps. This means they will pull a longer bar than the modern equivalent .cc without bogging down, and will get there in time.
If you want to cut rings every now and again and don't have a 70+ cc saw then they are the cheapest option available. If the price is right, I'd go for it, but see whether it has the chainbrake or not.
Alec
Agree with the first reply; if you aren't too bothered about speed, anti-vibration and (probably) lack of a chainbrake, then it will do what you want it to. It's an old saw from the time went torque was King, but running well, with a sharp chain and not used too often (unless you want to lose sensation in your fingers) it will eat plenty big wood for you.
I'd be happy with a good one under £100
Standard is 61cc, the Super is 72cc.
Standard will be comfortable at 20" but will pull 25". Super will be comfortable at 25" but will pull 28".
I would agree that if under £100 with the spare alongside it that would be well worth having.
Alec
