Hiya people just brought a ms230 couple of months ago first start of day starts fine then after that it wont all i can smell is fuel could someone enlighten me what this could be
cheers dean
Sounds like you're flooding it.
Cold start: choke on, pull until it fires, choke off, pull until it runs.
Hot start: put switch to I and pull until it fires.
The 230 has 4 settings on the switch, Off (O)
On (I)
Half revs (I I I)
Choke (I/I)
When cold starting, choke off means pushing the control lever up to half revs, but the saw just simply needs to be in the on position after (don't re-choke) if the saw is warmed
