What do members use for the ratio between solid wood and loose chip volume? I use 1 solid to 2.38 loose (from experimentation). I note that the Gemserve people who run the Biomass Suppliers List use a figure of 1 solid to 3 loose - never heard of a figure as high as that - but I suppose they are the experts!
I use 250kg per cubic metre when calculating wood chip in our shed. If the unchipped wood is around 600 kg /M 3 then that gives 1 solid to 2 .4
I would say you are closer than they are.
