I'm looking for parts for a Jonsered 630 Super 3.
Which Husky is it the same as?
also what bar fittings should I use. It seems to be missing the original Jonsered small to Husky adapter.
on the subject of bars.. I've seen Stihl bar> Husky adapters. How do you rate these and will they work on the 630?
Thanks
There were no "same as" system back then, even though that one was made at the Husky factory (as were all Swedish made Jonsereds from 1987, and some, including the original 630, from 1982) - and was based on the 162SE.
The 162SE was discontinued long before the 630 matured into the Super, and later the Super 2.
Thanks.. not quite the answer i'd hoped for however certainly the one I needed..
So what would the 162se have evolved into that may be mostly the same as the super? Or was the super's improvements based on Jonsered's engineers and as such is it incomparable?
The 162 was for all practical purposes replaced by the 266, that was the same basic saw with a larger engine. The Jonsered 670 was again based on that one.
Then it became really complicated with that "saw family", and nothing else really is close to the "Super" versions of the 630. Some parts interchange with one model, some with another, and so on.
Studying the parts lists may be the best way to start learning what's the same and what's not.
Is there any parts you already know that you have to replace?
The 630 always came with the large Husky Mount (D009), as far as I know.
Adapters to use the 9.5 mm Jonsereds mount (D025) hardly are availiable today.
Thanks.
as of yet only a couple of things which not too complicated. Sprocket, bar, carb overhaul and Bar Plates.
What lead to the question was seeing the Bar Plates under various Husky models with the same part number. I'd like to get new fuel hoses and also... Out of curiosity, what to do with these filters? Should the wash down?
