Hi, probably me being an idiot but if anyone can help if be grateful.
I have a '97 entec ch25 like the timberwolf tw125. Problem is that I need to change the battery on it. It s housed next to the hydraulic an petrol tanks which are directly under the feed shute. The space between there and the wheel arch isn't big enough to slide the battery out.
I'm without manual for the machine and guess I may need to remove some parts maybe but before I do if anyone can point me in the right direction I'd be very grateful.
Like I say probably just me being a fool.
Thanks
Sent using Arbtalk Mobile App
Loosen the 4 nuts holding the infeed chamber. Completely remove the bottom to and slacken the top to as far as possible without them coming off. This should give you enough play the move the hopper up and slide the battery out.
