Hi,
Β
I am looking to put a hiab on my truck which is a 5.5gvw. I want to run it using a pto pump off the gearbox, Its an isuzu nkr, Has anyone had any experience with this, or no where i could get one? cant seem to find anything on the net.
Β
Failing that, would an normal electric pump like i use for lifting the tipper do the job as well?
Β
Any help would be great
Β
Thanks
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
