no stress kicking in too often on 03 safetrack 150 35
  • 3 weeks later...
Thought I'd post this incase anyone else has the same problem in the future...
From PeteB:
Hey Dean, I couldn't post a response for some reason - cut and paste this if you feel the need!
The device maybe reacting too fast due to a fuel issue! Check the following;
Is maximum rpm being gained on the throttle?
Is enough fuel getting to the engine? (blocked filters, fuel line or damaged fuel line)
Is the air filter clean?
Other things to check;
Are the drive belts really tight?
Has someone messed with the settings inside the control box?
Call Mac or Jason at GreenMech on 01789 400044 or Cambrian Plant on 029 2056 9311.
to update all these things have been checked and seem fine..
I'm told the next things on the list to check are the alternator and the control box.
Can these be checked without having to replace them for new items?
