Hi All,
Hope someone could help on this I own a good condition 200t, that has carb issues 2007 model.
a mate of mine has a new unused carb for a pre oct 2006 model 200t.
would this carb fit my 2007 model and run with out any problem.
Thanks in advance Matty :thumbup1:
Hi All,
I would have thought so I have a old 020 carb on my 2010 ms200t and I haven't had any problems.
Hi All,
All the carbs from 020T through to late model MS200T are interchangeable. The 020T can be a bit finicky to tune but you are OK - if th ecarb is a known good one with no idling or high speed issues, it should just bolt on and run.
You may need to tweak the H/L/Idle screws but that is normal!
