chipper blocked today,cleared it,started,flywheel not turning and wobbly with a bar,will strip it out tomorrow but guessing the shaft has snapped? if so is it a difficult job? thanks guys
Hello, I would recommend taking the machine to a Timberwolf dealer on this one unless you have a high level of fitting skills and access to workshop equipment (e.g hydraulic press, lifting equipment etc)
Hope this helps
thanks for the advice,its now stripped and the shaft is clean in half! excellent advice and parts back up from gareth and mark at spectrum plant,my local tractor garage are happy to rebuild it with mark on the phone as back up :thumbup:
