hello when you put a few tankfuls of fuel through the saw will be free and run in and also the chain will be stretched which will give you some room to put a 8 tooth sprocket which will give you faster cutting speed the dolmar 9010 comes with a solid guide bar and you get alot of drag when cutting i put a oregon power match 32'' bar on mine with a sprocket nose and it was a different saw and i iam not sure if your makita has a sprocket nosed bar or solid bar but please P.M me and i will explain further
thanks
andrew
thanks
andrew
Thanks mate will think about that in the future thanks for your reply
regards
Ian
