Isuzu NKR 57 reg
Heapsfarm
I've a 57 reg NKR. Great for carrying the weight, plus with exhaust brake it's great getting down steep hills with said weight... However, anyone any idea of how you get change the side-light bulb without removing the door!?.. You can get to the headlight main beam underneath the truck. Removing the front panel doesn't give access to the light unit and tilting the cab means nothing :/ .... You can see the back of the bulb through the crack of the door when open, but can't get to the bulb.... Am I missing something so obvious here....
