Usually that means you cant turn it off but it will run ok .:001_smile:
Correct - the switch is normally open and unlike "normal" switches that are normally closed to turn something on.
It is possible the wire has chaffed and is earthing - you can disconnect the blu wire from the coil and try the spark again.
Saws that have been flooded can take a bit of getting going again!
