I like Oregon RA chain if you can find it.
It's full skip factory ground to 10o on the top plate.
The problem with most custom ground chains is they take the hardness out of them when grinding the top plate and you can't keep them sharp.
Use maximum bar lube and wear a dust mask to protect yourself from fumes.
Get your log up off the ground when you can so you aren't all humped over.
