Switched on our machine today and bleeped continuously reading 'Ser', was able to fire it up but now bleeps every time we turn it on. Hour meter is reading 100hrs, we had it serviced at 50 and the next interval I understand is at 250hrs so why the warning? It is also taking a little longer to start when first switched on for the day too; oil levels etc all good and proper.
Β
Any help appreciated, thanks in advance.
Edited by PeteB
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
