I require a clutch assembly for an older model (metal chain brake handle) 266. Its the one with the coarse thread 1/2" UNC. New or used if anyone has any ideas. I tried the usual ebay suspects without joy.
  • ย
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. ย
If you're just starting out and you need business, equipment, tech or training support you're in the right place. ย If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,ย ย then you're welcome too.
ร—
ร—
