Hi I just bought a I.S.C 203 mini rope grab and flip line kit from honey brothers. I've not used a rope grab since I was at merrist wood arb school back in '98! how do you get grab on the flip line? It appears you have to unbolt the cam ( the instructions say the cam is not removable). If I unbolt it does anyone know if there's a torque setting to wind nut up to- should it be replaced with fresh nut? Cheers for any advice on this. Mike
Undo the bolt, reuse original nut. Check its still there before each use, wouldnt worry about torque setting.
The non-removable bit is just to distinguish it from the type with a pin rather than a bolt.
The nut is a ` simonds locknut`.It relies on the ring of nylon for its ability to lock the thread.Obviously you wouldnt want to do, undo it repeated times, but just to fit it would be fine.I`ve done a couple and they`re still tight.
  • 3 months later...
