The 7m reach crane is £19700 + vat but in the spec sheet I got it has a
6.7 m reach the 8m which has an 8m reach is £23000 + vat plus £3500 optionl front tank and pump
Know anybody close with a Botex roof mount. It's more than likely on the spools so try it out. If it does what you want then no need for a front tank.
If you try a trailer mount one the pump on idle is about the same as running it on the spools.
