Mac 335 carb settings
bofh
Hi folks, I picked up an Mac 335 the other day, sparks well, got good compression etc but no go :001_huh: Someone has removed the plastic screw position holders and been tinkering.
So if you know what the standard settings are for the screws I'd appreciate it :001_smile: It's also missing it's air filter, would that affect the mixture too badly?
Give Simmonds Saws a ring on 01428 707269 they have all the parts you need, from memory it's 1 1/4 each to start then fine tune, don't over tighten when closing and use a small screwdriver with a clip or marked point on handle to get the 360 view.
Running without an air filter will change the mix a lot, and suck crap into the carb.
Then its a good clean out, possible blast with an ultrasonic cleaner and new pump and gasket set.
Good luck if your on a budget
  • 7 years later...
