Hi guys just inherited an old Murray 10/30 mower.
Engine is Briggs and Stratton 10hp.
It had sat for around and the inlet looked as if it was full of sand.
I've stripped it down and split the case and the internals look okay. The exhaust valve looks a bit burnt and I will replace.
My concern is the notch in the piston, is this normal ??
Perfectly normal. It shows which way is up.
great thanks.
It looks as if it may have ran lean or gasket was leaking. Hard to tell as it has sat around for so long though.
Sent from my GT-N7000 using Tapatalk 2
