i have pretty much solved many problems with my tw150, the only 1 that baffles me is why it wont roll on its own without jamming something in the forward switch, which is bad i know, please give me ideas and i will try the ones ive not tried.
Regards Kieron
07504 366361
Before And After
Trees And Landscapes
Hi Hedgecutter
If the forward feed rollers will only work with the forward button held you probably have either a faullty forward relay, switch/s or maybe a wiring issue.
Give Timberwolf's technical support a call, they will be able to give more in depth support on this for you, dont forget to have your machine model and serial number ready.
Timberwolf Technical support can be reached on 01449 765820 :thumbup1:
