Greenmech WoodChipper Help
jeff57
Hi Guys
Im having trouble starting my Greenmech Wood Chipper. It was working fine yesterday, untill the last time I started it, started fine, but when I pulled the large red lever to engage the chipper belts to stalled, and since then it won't start. Diesel engine turns over ok, as all seams fine, 3/4 of a tank of fuel but it won't fire up.
Ive cleaned all the connections to the battery and all the other connection but still no joy.
Your thoughts here would be greatfully appricated.
Cheers Jeff
Hi Mark
Just found the problam. Having checked every connection and checked all the fuses, it seams I missed one. It was tucked up behind the starter motor (yellow 20amp fuse) cleaned it out and put a new fuse in and it fired up straightaway.
Cheers Jeff
