Hi All this is my first post, so be gentle :biggrin:
Okay I have this prussik cord, i think its Amour Prus.
I have done a class 2 db splice,
using 1 fid (210mm) = 21 x 10mm (diameter of cord)
I have found that the cord is very stiff, should i be using different measurements or a different splice?
The rope still needs whipping, but i thought I would
ask you guys for some advise.
Cheers
Armor prus requires a core dependent splice so class 2 is what is recommended, however it can also be done with a class 1 splice or a exposed eye locking Brummel splice as these can be done a hell of a lot shorter than a class 2
Class 2 just leaves the legs way too stiff for use as friction cord. Which is why people use a modified class 1 for friction cord applications
