Good afternoon all,
Apologies for raising this question again, I though I had it sorted. Many thanks for all of your feedback. However, finally I've had a reply from Husqvarna regarding the grease. They say I should use their 531 00 92-05 grease. This is a 400g cartridge, and retails at £31.00. Does anyone know what the hell's in the stuff? Maybe we should by shares in it. Whatever it is, I'm sure it's not that unique, and cheaper to buy elsewhere if you knew what's in it.
Thanks,
Bosun
I just use standard grease in all out stihl gear. It needs doing so regularly there's no point in using expensive stuff.
All my gear has done 2 season being serviced with standard grease, with no bearing failures at all.
Sent using Arbtalk Mobile App
