Where the hell does everyone get the large bags from, please help me as i had 20 builders dumpy bags in September and now nothing, so i need some more so i can start storing for next year and so on.
  • Replies 25
Jojam.
There are many wire mesh stillages about but we went for this design mainly because:
Will flat pack when not in use!!!!!
Fit on standard pallets so the bit that gets damaged can easily be replaced
Galvanised rather than plated.
Can be opened up to tip contents
Heavy duty construction
Will stack 4 high (but we only do 2 high)
The cages just clip around the edges of the pallets - internal dimensions are 60cm x 93cm x 114cm: 0.64 cubic meter.
An important point for us was that this volume of wet hardwood is about the maximum weight that our small tractors can handle safely.
We bought the stillages in second hand from a dealer in Europe. Plenty of knocks bumps and bends but they are rock solid and will see me out. They cost around £40 each by the time vat and transport had been added so are not cheap but have been a good buy for us.
cheers for that marko.process to order jist now but thinking of cuttin an storing for dryin.not sure which way to go our half load 2.5 cube an full load 5 cube.
cheers for that
Edited by Amelanchier
I hate scrolling
  • 4 years later...
We have a system similar to Posch. Process fresh and you get quick drying. Forklift friendly, so a lot less labour.
Timberland
has timberland dissappeared , pm sent.
can some one pm me his contact details.
cheers bob
