does anybody know if the crank shaft bearings and seals from a husqvarna 372 will fit on a 576xp autotune? a lot of the parts from a 372 will fit a 576 so i was wondering if anyone has tried this or knows if it's possible,thanks in advance guys,mike.
The 372 bearings are part - 738 22 02-25 the 576 bearings are - 525 43 43-01
Looks like they may be different - if you measure the ones off your 576, I have just stripped a Jonnie 2065 that has the same crank and bearings as a 372!
