  • Replies 26
Good luck with it anyway, I guess the sling is the most simple and least kit intensive. Hope you find something good.
Ok so some pics of the setup I copied as it stands as of tonight...
Seems to work pretty well, and should do the job...any comments appreciated.
[ATTACH]110566[/ATTACH]
[ATTACH]110567[/ATTACH]
Got a tree I can try it out on tomorrow
Just looked at this and it looks hideous!
Who cares what other people think.. If you are worried about choking the sling on the small diameter carabiner hole on the LJ why not girth the sling to your bridge ring and have the biner on the LJ and the other end of the sling.. Seems like the most simple way to run it. I guess the only advantage the o rig has is that you can adjust underload and you dont have to unhook from the system.
Your right I don;t really care what people think ....decided to go the the other way though now and stripped it right out...I'll just throw a sling on when needed..Cheers :thumbup1:
