Hi all, Trying to set the Camshaft position on a little gx160 engine I have but there is nothing that I can distinguish as timing marks on either camshaft or crankshaft.
If I put the piston at TDC where should the valve position be?
any help would be great as its getting really annoying!!
If there are definitely no marks I think you can only do it with a timing disc, you may be able to download one and make it?
https://www.google.co.uk/search?q=making+a+timing+disc&hl=en&client=safari&tbo=u&tbm=isch&source=univ&sa=X&ei=6iHrUMufAofC0QXMtYC4Ag&ved=0CDEQsAQ&biw=1024&bih=672
I've done this in the past good luck
Edited by Andy Collins
Read more
