husqvarna 351 worth fixing?
Northern Log Dog
Not familiar with the 351, but if it is a magnesium cased saw and the crank/seals and rod are good, should be worth getting it running again for a backup. Make sure to find the problem that caused the seize to start with.
Looking at the specs for a 50cc saw it seems a little low on power for a primary felling saw when compared to the 346xp and 550xp.
But this reply is also based on you being able to do the work yourself. Taking it to a saw shop may make it price wise not feasible.
Here is the IPL for part numbers if you need it. http://www.husqvarna.com/ddoc/HUSI/HUSI1999_AAaa/HUSI1999_AAaa_I9900055_.pdf
